Dialing distribution
Post by 10111989 »
Dear All,
I am using 3 PRI all are providing us by different vendor One is TATA, one is RELIANC, another one is BSNL.
I defined prior link as TATA PRI so all O/G call are routed by it i want to implement my some calls like some state dialing O/G calls should be only gone by BSNL link but the issue is when i press 0 I got the access of my TATA PRI because i defined
┌─Consult/Modify: Prefix Plan─────────────────────────────────────────────┐
│ Node Number (reserved) : 101 │
│ Instance (reserved) : 1 │
│ Number : 0 │
│ Prefix Meaning + Professional TG With Overlapping │
│ Prefix Information : 10 │
│ Private Route type + False │
TRUK GRP 10 IS TATA
MY requirement is for example-: If anybody press Bangalore state code 080 and then extension no of bangalore state(xxxxx) it;S calls are routed by BSNL PRI which was not happend presently when i pressed 080 code & then extension no calls are going via TATA link.
I hope you understand the issue if u have any other query regarding the issue plase tell me i will try my best to provide u the required details.
Warm Regards
Gaurav Singh :lol: 8)
murraya
Re: Dialing distribution
Post by murraya »
hi, this is don by use of ARS,
define prefix 0 as ARS and configure as required.
Please read system docs on ARS. you will need to configure the discriminator rules. set up separate rules to the trunk group you want based on digits dialled.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
yeah ARS MANDOTARY
or some brain burning to make it works:
lot of play with discriminator /trunkgroup compatibility , overflow etc ...
