hi, just a starter question before I go down this path.
a customer requires to pass CLI and pilot information to a call recording client that is running on the agents PC.
I believe this will be possible but I would like your thoughts before investing much time into it.
each agent has CCA and the recording client loaded onto their local PC.
I assume we will need to use the SDK to develop the link though.
CCA to pass pilot and CLI to another app on the Client PC
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Re: CCA to pass pilot and CLI to another app on the Client PC
You need CCA source code, modify and then call your recorder SDK on CCA
cheers Cav, so in theory possible.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Yeah, as long as you have correct tools, why not.
anyone actually done it?
I assume its much like creating a screen pop from a database, pass cli to database to look up customer details, pop on agents screen.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
I have but with Qfiniti recorder who do provide a SDK. You say about messing with db directly... That can be risky as usually recorders handle more than one table for each call
