HI all, I'am trying to create a VM using VB versione 5.0.4 but I get an error of "Kernel Panic" when VM starts and try to install sw ( using OXE PC Installer ).
Does anyone had tried?
P.S. if I use Vmware no troubles.
Virtualbox 5.0.4 and OXE v. 11
Re: Virtualbox 5.0.4 and OXE v. 11
it works for me with virtualbox 5.0.6 on a macosx 10.11 hostsystem. I have never used 5.0.4 but i've had also a kernal panic with latest 4.x.x virtual box systems after upgrade to macosx 10.11.
actual version of virtual box is 5.0.8 (but i haven't tried).
regards...
regards...
agiftel
Hi TGN and thanks for reply.
I've updated Virtualbox to last versione (5.0.8 ) and now it works!!! I'am using as host a MAC Book PRO, OSX v. 10.11.1
Regards!!
Regards!!
fine ... so i will update to 5.0.8 too
regards...
regards...
Nico_1
Hi guys,
on my virtual box works a OXE, but i can't install a software key how have you fix this problem?
Nico_1
Yes its unable to import the OPS file becorse i have no CPU ID on the virtual OXE
Lol, of course you don't. You run it just for 30 days
and 30 days are good for testing purposes and so a better option than an opentouch system has in license handling....
so this is no issue...
regards...
regards...
