Hello Everyone!
Version: 4760.4.2.10.02
We had problems with the network connection.
Windows Event Log (System):
- Anwendungspopup: db_archive.exe - Fehler in Anwendung: Die Anwendung konnte nicht richtig initialisiert werden (0xc0000142). Klicken Sie auf "OK", um die Anwendung zu beenden.
- Anwendungspopup: DeleteFiles.exe - Fehler in Anwendung: Die Anwendung konnte nicht richtig initialisiert werden (0xc0000142). Klicken Sie auf "OK", um die Anwendung zu beenden.
After this time NMC services did not start completely.
Windows Services:
- NMC Service Manager (svc_mgr) - State: (not started)
- NMC50 Database (ASANYs_nmc50) - State: started
- The other MNC services are not visible
The Disk Space is 50GB with 16GB free.
Here are the logfiles:
NMCsvc_mgr_2.log
[23.11.2015 23:03:48] 220 svc_mgr: starting...
[23.11.2015 23:03:48] 220 svc_mgr: controlled services won't be allowed to interact with desktop
[23.11.2015 23:04:48] 564 svc_mgr: Error: connection to LDAP server failed (error 85: Timed out)
[23.11.2015 23:04:51] 564 svc_mgr: closing LDAP connection
[23.11.2015 23:04:51] 564 svc_mgr: Error: cant extract last threshold for LDAP
[23.11.2015 23:04:51] 564 svc_mgr: Error: cant extract last threshold for SQLA
[23.11.2015 23:05:06] 564 svc_mgr: connected to LDAP server on XXX:389
[23.11.2015 23:05:13] 564 svc_mgr: installing service 'CleanMib@XXX'...
[23.11.2015 23:05:22] 564 svc_mgr: starting service 'CleanMib@XXX'...
[23.11.2015 23:05:26] 564 svc_mgr: installing service 'Apache@XXX'...
[23.11.2015 23:05:27] 564 svc_mgr: starting service 'Apache@XXX'...
[23.11.2015 23:05:33] 564 svc_mgr: installing service 'ExecdEx@XXX'...
[23.11.2015 23:05:34] 564 svc_mgr: starting service 'ExecdEx@XXX'...
[23.11.2015 23:05:38] 564 svc_mgr: installing service 'Extractor@XXX'...
[23.11.2015 23:05:40] 564 svc_mgr: starting service 'Extractor@XXX'...
[23.11.2015 23:05:45] 564 svc_mgr: installing service 'LicenseServer@XXX'...
[23.11.2015 23:05:46] 564 svc_mgr: starting service 'LicenseServer@XXX'...
[23.11.2015 23:05:53] 564 svc_mgr: installing service 'SaveRestore@XXX'...
[23.11.2015 23:06:01] 564 svc_mgr: starting service 'SaveRestore@XXX'...
[23.11.2015 23:06:10] 564 svc_mgr: installing service 'Scheduler@XXX'...
[23.11.2015 23:06:10] 564 svc_mgr: starting service 'Scheduler@XXX'...
[23.11.2015 23:06:16] 564 svc_mgr: installing service 'SecurityServer@XXX'...
[23.11.2015 23:06:17] 564 svc_mgr: starting service 'SecurityServer@XXX'...
[23.11.2015 23:06:24] 564 svc_mgr: disk limits not reached for A4400SaveRestore
[23.11.2015 23:06:29] 564 svc_mgr: Warning: maximum disk limit reached for Accounting
[23.11.2015 23:06:29] 564 svc_mgr: disk limits not reached for Collector
[23.11.2015 23:06:29] 564 svc_mgr: Warning: maximum disk limit reached for LdapPath
[23.11.2015 23:06:29] 564 svc_mgr: Warning: maximum disk limit reached for NmcDataBase
[23.11.2015 23:06:29] 564 svc_mgr: disk limits not reached for NmcPath
[23.11.2015 23:06:30] 564 svc_mgr: disk limits not reached for NmcSaveRestore
[23.11.2015 23:06:30] 564 svc_mgr: disk limits not reached for OXESoftwareDownload
[23.11.2015 23:06:30] 564 svc_mgr: Warning: maximum disk limit reached for OxoSW
[23.11.2015 23:06:30] 564 svc_mgr: disk limits not reached for OxoSaveRestore
[23.11.2015 23:06:30] 564 svc_mgr: disk limits not reached for TempDirectory
[23.11.2015 23:06:30] 564 svc_mgr: disk limits not reached for WebClientSessions
[23.11.2015 23:06:30] 564 svc_mgr: Error: Not enough diskspace : LDAP [THRESHOLD2] - SQLA [THRESHOLD2]
[23.11.2015 23:06:30] 564 svc_mgr: NMC service : svc-mgr will be stopped to prevent data crash
[23.11.2015 23:06:31] 564 svc_mgr: stopping service 'Apache@XXX'...
[23.11.2015 23:06:34] 564 svc_mgr: uninstalling service 'Apache@XXX'...
[23.11.2015 23:06:34] 564 svc_mgr: uninstalling service 'CleanMib@XXX'...
[23.11.2015 23:06:34] 564 svc_mgr: stopping service 'Extractor@XXX'...
[23.11.2015 23:06:40] 564 svc_mgr: uninstalling service 'Extractor@XXX'...
[23.11.2015 23:06:40] 564 svc_mgr: stopping service 'Scheduler@XXX'...
[23.11.2015 23:08:04] 564 svc_mgr: uninstalling service 'Scheduler@XXX'...
[23.11.2015 23:08:04] 564 svc_mgr: stopping service 'ExecdEx@XXX'...
[23.11.2015 23:08:05] 564 svc_mgr: uninstalling service 'ExecdEx@XXX'...
[23.11.2015 23:08:05] 564 svc_mgr: stopping service 'LicenseServer@XXX'...
[23.11.2015 23:08:06] 564 svc_mgr: uninstalling service 'LicenseServer@XXX'...
[23.11.2015 23:08:06] 564 svc_mgr: stopping service 'SaveRestore@XXX'...
[23.11.2015 23:08:07] 564 svc_mgr: uninstalling service 'SaveRestore@XXX'...
[23.11.2015 23:08:07] 564 svc_mgr: stopping service 'SecurityServer@XXX'...
[23.11.2015 23:08:08] 564 svc_mgr: uninstalling service 'SecurityServer@XXX'...
[23.11.2015 23:08:08] 564 svc_mgr: closing LDAP connection
[23.11.2015 23:08:08] 208 svc_mgr: NmcLocale set to 'de_DE' from LDAP...
[23.11.2015 23:08:12] 208 svc_mgr: NMC service : slapd-4760 will be stopped to prevent data crash
Thanks and regards,
Marco
4760 Startup Problem (NMC services start, stop and disappear)
Re: 4760 Startup Problem (NMC services start, stop and disappear)
eventhat you have limitation
see [23.11.2015 23:06:29] 564 svc_mgr: Warning: maximum disk limit reached for LdapPath
you can check at Direcory /system/nmc/servername /servers/servername/ ldappath there are two threshold
same for nmcdtabase and oxoSW you may have to increase disk space limits for that services allocation(or i'm not sur make a dbse defrag).
SAT-IT
I can't login in the Directory Manager.
always appears "Can't connect to the LDAP Server".
Only NMC50 Database is running. (Windows Services)
DirManag:
Hostname:"NameofHost"
Portnumer:389
Login: cn=directory manager or AdminNmc or dba
Passwort:
Ldap Version: i tried both (ldap V2 and ldap V3)
Only Referrals is checked
I can via ODBC login to the database.
DirManag:
Portnumer:389
Passwort:
But have you freeded some space? Lol
You have the answer and still complain on same exact error?
How you expect behavior to change if you didn't fix nothing?
SAT-IT
I found the solution.
If i trying to start mnc services, i can login in the Directory Manager.
I have a little time to make the changes for ldappath, nmcdatabase, oxoSW and also accounting.
Now it works.
Great and thanks all.
Now it works.
