OXE GD3 static route
OXE_4400
Post by OXE_4400 »
It is possible to add static route through netadmin in OXE CS.
How will behave GD3 board? Can we do similar on it?
Guest
Re: OXE GD3 static route
Post by Guest »
no, maybe it works if you set up a static route with the route command in linux subsystem, but it is not designed to statically save it in configuration.
regards...
tgn
Post by tgn »
regards...
OXE_4400
Post by OXE_4400 »
But it is strange. netadmin allows to enter static route, but it seems no way for GD3
tgn
Post by tgn »
yes !
but network design guide says callserver has to be in a seperate subnet than the other equipment...
regards...
OXE_4400
Post by OXE_4400 »
OK, but I don't see conflict between GD placement in separate subnet and need to manage static routes. There are 2 different things.
tgn
Post by tgn »
not really a conflict... but the callserver is 'designed' to work in a central server subnet (with maybe more than one router and a static ip-address) and the gd is 'designed' to work in the 'endpoint' subnet just like an ip phone (with only one default-router and the possibility to get ip-addressdata from a dhcp server).
so the restriction is only made by the 'design'.
regards...
Just for understanding - for what you want to use static route? For signalling (GD-CS) or for RTP for TDM users from rack (GD-???).
OXE_4400
Post by OXE_4400 »
For RTP between TDM environment (PRA, UA) on rack and VoIP phones or SIP trunking.
Return to “IP”
