server load balancing on 6850
thomassm
Post by thomassm »
is there anybody with experience with this, i am trying to configure on a 6850 layer 2 unsuccessfully.
it seems that the servers are unreachable? (discover mode)
Cluster repo
VIP : 135.227.134.30,
Type : L3
Admin status : Enabled,
Operational status : Out of Service,
Ping period (seconds) : 60,
Ping timeout (milliseconds) : 3000,
Ping retries : 3,
Redirect algorithm : round robin,
Probe : http,
Number of packets : 0,
Number of servers : 2
Server 135.227.134.31
Admin status = Enabled, Operational status = Discovery,
Weight = 1, Availability (%) = 0
Server 135.227.134.32
thanks!
-tom
Re: server load balancing on 6850
Did you mean SLB or NLB?
thomassm
Post by thomassm »
i was referring to slb
thanks
-tom
Did you have configured at your servers the same loopback addresse like declared in network guide. At the loopback interface there may be no gateway address to configure.
thomassm
Post by thomassm »
we configured one, but it stayed in the "discovery" state on the switch
thanks
Thomas
I never tested it in last 10 years. Only in my ACSE certification I did - it did work.
Below is the steps for creating the loopback and to enable
forwarding, weakrecieve and weaksend for both loopback adapter and the
local area connection.
1. Install the Loopback adapter in WIN2008 as it is not installed by default.
2. Configure cluster IP to the Loopback adapter.
3. Issue the ipconfig /all command on the command line to determine the interface name of the loopback adapter.
Ethernet adapter Local Area Connection 2:
Description ...Microsoft Loopback Adapter
In this example we have “Local Area Connection 2” as the name for loopback
adapter.
4. Alias the cluster IP to the loopback using the following netsh command :
netsh interface ipv4 add address "Local Area Connection 2"
cluster_ip_address
5. Enable forwarding for the loopback adapter on the machine with the following
command in the command prompt
Netsh interface ipv4 set interface "Local Area Connection"
forwarding=enabled
After the command, we should receive an "OK" message
6. Enable the weakhostrecieve and send for the loopback adapter and the physical
netsh int ipv4 set int "Local Area Connection"
weakhostreceive=enabled weakhostsend=enabled
netsh int ipv4 set int "Local Area Connection 2"
This will make the server to respond to the SLB VIP configured in the AOS switch
configuration.
lmherdvera
Post by lmherdvera »
Guys, need help to this problem:
Starting dynamic software load from '/flash/certified/'...
unable to load Stack Manager Library - ABORT!
Thanks...
