Can use GA-3 except GD-3
shirantha
Post by shirantha »
we have only GD-3 board in hand , may i can use it for GA-3 , what we do ?
Shirantha
Re: Can use GA-3 except GD-3
I hope yes - just change micro switch on the board.
shirantha
Post by shirantha »
No any micro switch on board @ GD-3
shirantha
Post by shirantha »
I tried to config GD3 as GA3 , but it can,t downloaded Brynner from main GD3,
It Appears
""Booting suspended because of shutdown request or lack of main power"
Kindly advice me How to solve this issue
Please refer attached screen shot
Tks,
Shirantha
mgoegel
Post by mgoegel »
I had the same problems last month.
I had ordered a GA3, as I had not found a solution.
When comparing these two boards, it seems not possible, as these boards are equipped differently.
I have some photos. Tell me if you want to see them ;-)
Regards Mario
Gesendet von meinem D5803 mit Tapatalk
sadim
Post by sadim »
According to TC1372, DIP switch should be on the right of the battery
TC1372:
2.1 Visual check
− Check that the SDcard is present and properly plugged. It is located on the rear panel of GD3 / GDA3. SDcard is the flash memory of NGP couplers. Its size is 256 MB. It will subsequently evolve.
− Check the position of the DIP switches.
Note
The DIP switches on the NGP boards have not to be changed. The only reason for which it could be modified on GD/GA boards was to enter in LOLA mode: with NGP boards, this mode is useless as a flash format is automatically performed when a network boot is done. Besides this component is quite fragile.
− GD3: 2 is ON and 1, 3, 4 are OFF. They are located on the right of the battery.
− GA3: 1, 2 in ON and 3, 4 are OFF
mgoegel
Post by mgoegel »
What a terrible color sadim, I hope I don't get eye cancer.... 8) :lol:
Take yourself a look on these pictures. I don't see any DIP switches.
I'm sure, that sometimes documentation is only copy'n'paste in combination with search and replace...
Mario
OXE_4400
Post by OXE_4400 »
Official answer from support:
please note that not all the GD3 editions support the DIP switch, only the ones with USB in the front panel have this DIP switch.
Hence, the GA3 boards role cannot be changed to GD3.
There is no official document which states that changing the switches can convert GD-3 to GA-3 and vice versa.
HUSSAINQCS
Post by HUSSAINQCS »
Is there possible to work GA3 same like GD3 for shelf configuration with OXE vmware ?
jetcster
Post by jetcster »
There is an OXE MS for that.
Return to “Boards”
