OXE does not react on 302 moved temporarily
H-MAN
Post by H-MAN »
i have a little problem with two OXEs R11.28b
Both are connected via SIP external gateway with ABC-F Trunks. Access to the other node is done by ARS.
If i call an extension in the second node which is forwarded on no reply, the first one does not react on it or recalls the forwarded extension again.
The node 2 sends 302 moved temporarily but the OXE seems to ignore it.
I tried the same in my lab and had no problem. After loading the customder DB i get the same error. I compared the SIP settings and found no problem.
Maybe anyone has a suggestion for me.
Thanks.
Shit happens!!
samet
Re: OXE does not react on 302 moved temporarily
Post by samet »
you should change trunk group type.you can try trunkgroup type with ISDN all countries
Return to “SIP”
