Hello everyone
Please if you can help me in here. We want to monitor OXE on the free monitoring software such as the Nagios.
I think it will need the SNMP Trap License on the OXE and MIBs to be loaded on the SNMP Manager - Nagios.
Please if some one can tell me from where I can get the MIBS and import into Nagios.
Tenna
OXE AND SOLARWINDS
- tot3nkopf
Re: OXE AND SOLARWINDS
In OXE:
/etc/snmp/mibs/export/
Do you have SNMP trap license on the OXE (lock 153)?
Tenna
Hi tot3nkopf
The Lock 153 is Yes. Is it possible for us to get the MIBS from BPWS
Tenna
Tenna
Tot already gave you the path from where to get them, not BPWS
KIKA
Hi Everyone,
Does somebody have screen about how snmp trap or any snmp looks with a events of OXE?-
This is the first time I have to work with this, I already did the configuration and also I already have informttion in SNMP Trap.
But, for me, the information it's not showing in a "friendly" way, I have to open each line, scroll down and find the incident.
This is why I want to see screens of the others SNMP to check if I missing someting in the SNMP monitor configuration.
than you!
than you!
- tot3nkopf
You need to implement the SNMP MIB on Solariswinds and use MIB parser with this MIB file.
Then you will have more "friendly" output.
KIKA
Hi, I was using SNMP Trap but I'm going to use Solarwinds to check incidents, Could you please tell me which product choose?tot3nkopf wrote:You need to implement the SNMP MIB on Solariswinds and use MIB parser with this MIB file.
http://www.solarwinds.com/downloads
- tot3nkopf
I guess you need to go on Solarwinds support or forums: https://thwack.solarwinds.com/thread/16217
Solarwinds is only one of the many network monitoring tools.
