No Voice from OXO to OXE
mujib.alu
Post by mujib.alu »
I have OXE and two OXO systems connected on SIP, Internal and External calls work fine.
scenario:
OXE range 1000 - 1999
OXO range 2100 - 2199
on OXE user 1000 associate set declared as 1001,
if OXE user 1999 called 1000, after 4 rings calls forward to 1001 and its work fine
if OXO user 2100 called 1000, after 4 rings calls forward to 1001 and its ringing, once they answered no voice both side
any idea..?
Thanks in advance..!
Re: No Voice from OXO to OXE
Traces?
1001 in the same IP domain as 1000?
mujib.alu
Post by mujib.alu »
yes its in the same IP domain
1000 and 1001 - TDM or IP sets
SIP TG (OXE) - ABC-F or T2 all countries
prefix "PBX address in DPNSS" - was created or not
mujib.alu
Post by mujib.alu »
hi Vad,
All the users are IP sets ( OXO and OXE )
SIP TG : ABC-F
PBX address in DPNSS : created
the problem only on Associated routing condition, whereas pickup, transfer and hunting groups working properly
Return to “SIP”
