ldap directory is synchronizing with 4400 but I do not want
knightr1der
Post by knightr1der »
Hi Guys,
I have a small problem.
I have manually created a user in LDAP directory and he, by chance, has the same name as a real user on 4400. I do not want the 4400 user in the LDAP directory.
After some time, the LDAP is creating a link to the real user. I do not want this to happen. I have disabled PCX Synchro in Directory > System > PCX entry
Why is this still happening?
Any help will be much appreciated as always :)
mgoegel
Re: ldap directory is synchronizing with 4400 but I do not want
Post by mgoegel »
I'm not sure, if this will work - maybe the 4760-OXE sync will not work after this (can't try it yet):
set (on OXE) System/47xx directory - 4400Synchro. to false
Mario
luckyme2
Post by luckyme2 »
mgoegel wrote:I'm not sure, if this will work - maybe the 4760-OXE sync will not work after this (can't try it yet):
Mario
Never do this. The whole synchro process will be stopped.
Better : Remove the primary link from your user in the LDAP directory. There will be no link
to the PABX name anymore.
knightr1der
I did this and the primary link re-appeared the next day :shock:
luckyme2
Post by luckyme2 »
Try out the option = Disable PCX Directory Synchronization.
It is logical that it works like that. Omnivista finds the same name and thinks it is the same.
Try also to change the first name of the person that has no link to the Pbx.
jancek
Post by jancek »
You can disable it in Setup / Administration / Application configuration / Application settings / DirectoryAdmin / AutomaticCreation / Create for users ( OXE ): FALSE !!!
It means after synchronization of OXE you will see no users in Directory application.
Return to “OmniVista 4760”
