4760i isn't running with internet explorer R11
ardemirtas_DUP
Post by ardemirtas_DUP »
4760i is used to run under IE R9 . After Upgrading IE R9 to IE 11 , 4760i isn't running . Is there anybody help about it ? Thanks for your advices.
Re: 4760i isn't running with internet explorer R11
As the tool has no support at all I guess is normal. Try another browser or use an older version
I prefer to use 4760i client instead of use brouser.
doublezero
Post by doublezero »
I also prefer the client
Gesendet von meinem A0001 mit Tapatalk
Return to “OmniVista 4760”
