PRA-T2 can't come Inservice ( INIT 2 RUN)
doublevand981
Post by doublevand981 »
Hi all,
my oxe running on R11. i faced problem with PRA-T2 board, it could not come inservice whenerver i reset card or reboot system. it's hang on INIT 2 RUN .
| 2 | 0 | GD3|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 5 | SLI2 8 (Z)|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 6 | PRA T2|---------- | INIT 2 RUN | BAD PCMS CODE |
| 2 | 7 | APA 4|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 8 | CS2|---------- | CALL SERVER | BAD PCMS CODE |
i must remove APA, SLI cards and PRA-T2 card also, then deleted and created again PRA card , insert PRA card back to system. it come inservice.
the problem come again whenever the system reboot or PRA card reset.
any pro can help me, pls !
doublevand981
Re: PRA-T2 can't come Inservice ( INIT 2 RUN)
any one can help me ?
i upgraded system to R11.1-l1.301-31-a-vn-c82 . the problem still there.
if the T2 access was created before the card was inservice, the hang will be hang on INIT 2 RUN.
i had to delete the T2 access on trunk group and reset card by rstcpl comand, then it came back to inservice.
Then I created T2 access and assiged to trunk group.
Did you replaced the board with another one to see if the behaviour is just the same?
doublevand981
yes. i tried with new one. and faced same behaviour
Which kind of CPU you have and how many boards?
doublevand981
i using CS-2 board, and only one now.
And how many boards on your whole system depending of this CS2? 3 full shelfs?
I ask because could be a processing issue where your CPU can't handle the whole requests and just won't start your board.
Have you tried a different position for it?
doublevand981
Hi pro,
the shelf here:
it NOT FULL.
i tried with other slot and other new PRA-T2 board. But got same behaviour.
i just want to confirm that
Weird, seems that processing is not the problem.
Usually I insert the board and system will initialize it.
If no TG using it then will get free but already running. Then you can add to a TG or create a new one for it.
If a TG is configured (scenario where you replace a board) then it should work without any issue...
Which version are you running?
doublevand981
Return to “Boards”
