is there Free CTI for OXE?
Ajay S
Post by Ajay S »
Hello Everyone,
my name is ajay and i work in a company in germany.
For while now I´ve kinda been in charage of phone related stuff.
If we get a new branch or a branch would want a new phone system i contact an Alcatelpartner and they built it and set it up and I just do basic support like changing numbers doing groups and stuff like that.
We have a few OXO´s in our company, however recently one of our branches upgraded from an OXO to an OXE and now as its done, our Alcatelpartner did not mention that pimphony does not work with an OXE.
Now my first question is, is that true ? and if so is there any alternative?
Re: is there Free CTI for OXE?
Not really. You need Open Touch for a softphone application.
Pimphony is only for OXO. As tot says for oxe you need OpenTouch or maybe TAPI? But still will need licenses on oxe side. There is no free solution.
alexeik
Post by alexeik »
i work for a businesspartner in Germany, so if you have questions you can write me an private message with your email adress so i will tell you all you want to know :)
greets Alex
Mind to share your solution with the forum?
alexeik
Post by alexeik »
sure,
like you said there is nothing free for OXE. You need opentouch, or csta licenses and a CTI-software. We sell 2 different cti-software, mostly estos procall, and secondly c4b X-Phone. Both are server/client systems for windows with clients for mobile devices.
i wanted to use private message because then we can talk in german :)
If you have more questions feel free to ask...
greets
Nice :) wonder if you have a Web site to see them or some brochure?
doublezero
Post by doublezero »
There is also an possibilty to use a other solution. With v24 Adapter and a server. User uses a small client. But i didnt know the Name of the Software i will check my Mails tomorrow
Gesendet von meinem A0001 mit Tapatalk
Maulwurf
Post by Maulwurf »
We use and sell also CTI and UCC Server Xphone Connect. it works with OXE and OXO.
I think it is a little bit cheaper to buy as Opentouch.
Here you can have a look: http://www.c4b.de/de/produkte/xphone-connect/
alexeik
Post by alexeik »
https://www.estos.com/
http://www.c4b.de/en/
the funniest thing is... We all know how long it takes to install opentouch. The Estos Procall system is ready to use in half an hour with ad integration and odbc connectors to show the data of crm/billing system or any other databases fot incoming call recognition...
i´ve attached a typical call window, so you can see what is possible.
