I need help whith a very basic RSI script.
1) Block: get digits: Assign to "digits" variable. (Voice guide: 666:1)
2) Block: Transfer to "digits" variable
3) End Script.
Its a simple automated attendant ¡¡¡
I appreciate if someone can send me the script.
OTCS Altitude RSI SCRIPT
joao.carlos
Re: OTCS Altitude RSI SCRIPT
Really? You don't want help, want someone to work for you?
? So why don't you do it?
GURUALE
This is my test script
version "8.1"
file version 0, 14
flow view {
audio {}
modules {}
dependencies {}
constants {}
types {}
variables {
digitos: text
parameters {}
campaign record {}
contact record {}
workflow record {}
transferred record {}
contact profile extensions {}
outcome record {}
cursors {}
on start {
goto node 'MAIN'
on end {}
node "MASTER" {
id 1
variables {}
cursors {}
on first enter {}
on enter {}
node loop {}
on exit {}
node "MAIN" {
id 2
master "MASTER"
variables {}
cursors {}
on event phone cleared()
on first enter {
set node audio all digits timeout to 15 inter digit timeout to 3
get digits into digitos {
play {
file "666:1"
on digits do {
goto node 'TRANSFERIR'
on timeout do {
on error do {
on enter {}
node loop {}
on exit {
end script
node "TRANSFERIR" {
id 3
master "MASTER"
variables {}
cursors {}
on error phone blind transfer
err: PhoneError,
user_name: text,
num: text
end script
on error phone clear
err: PhoneError
on first enter {}
on enter {
manual blind transfer phone to digitos single step
node loop {}
on exit {}
<?xml version="1.0" encoding="UTF-8"?>
<asl_meta_data xml_spec_version="8.1">
<debug_info />
</asl_meta_data>
a) Play guide ok
b) Get digits ok
c) Transfer to digits NOK. The call is released.
version "8.1"
file version 0, 14
flow view {
audio {}
modules {}
dependencies {}
constants {}
types {}
variables {
digitos: text
parameters {}
campaign record {}
contact record {}
workflow record {}
outcome record {}
cursors {}
on start {
goto node 'MAIN'
on end {}
node "MASTER" {
id 1
variables {}
cursors {}
on first enter {}
on enter {}
node loop {}
on exit {}
node "MAIN" {
id 2
master "MASTER"
variables {}
cursors {}
on first enter {
play {
file "666:1"
on digits do {
on timeout do {
on error do {
on enter {}
node loop {}
on exit {
end script
node "TRANSFERIR" {
id 3
master "MASTER"
variables {}
cursors {}
err: PhoneError,
user_name: text,
num: text
end script
err: PhoneError
on first enter {}
on enter {
node loop {}
on exit {}
<debug_info />
</asl_meta_data>
a) Play guide ok
b) Get digits ok
Can you take a tcp capture on oxe ip addess port 2555
Enviado do meu ALE-L21 através de Tapatalk
Hello
Transfer is not supported on ASL for RSI call.
Use divert phone instead.
Let us know the result.
GURUALE
Thank you very much.
I set to "divert" and the script now works ok.
- knightrider
Please use correct forum in future - I have moved this to OpenTouch Customer Service (OTCS)!!
Kind regards
Knight
Kind regards
Knight
