I can send faxes but cannot recieve
Locked
jbower
Post by jbower »
Hello All,
I have an AudioCodes MP-FXS112. I can get it to send faxes on my OXE, but i cannot receive faxes. Any idea of what settings i should look at? Sooooo many settings and it only takes one to hose it all up. Interop docs are like 10 years old so they are of no use to anybody.
Re: I can send faxes but cannot recieve
Codec? Logs as always would be a nice place to start instead of wild guessing
tgn
Post by tgn »
yes. logs and traces please. also how you connect it (protocol sip/h323) and which oxe ip hardware is in use (crystal or common and generation3 or not).
and just for fun... wild answer... the reason for your problem must be between heaven and earth... ;)
best regards...
--- back to basics... focus your eyes on the essential things... ---
jbower
Post by jbower »
Here is a *.ini file (actually a txt of the ini) of the configuration for the audiocodes sip gateway that shows the Codecs. I will try and run a SIP trace for some log information.
My PCX is Crystal on R11.1
I am using SIP to and T.38
When you receive call and press START - caller hear fax tone? or silence?
jbower
Post by jbower »
It is a multi function device. The process is totally automated.
Ermmm ok but disable the manual or just dial from any phone, you should hear the fax tone whether you dial from anywhere not just a Fax machine
jbower wrote:It is a multi function device. The process is totally automated.
As I understand - you have VoIP gateway and analogue FAX connected to VoIP gateway.
When you have incoming call:
- FAX will ring - caller hear RBT
- when FAX will answer - caller hear??? RBT, silence, fax tone ...?
jbower
Post by jbower »
Thanks for everyone's suggestions. I figured it out. So i was using G711A-law which allowed me to send faxes but would not allow me to receive them. So I changed the setting to G711U-law and i can now send and receive faxes. Guess it comes down to using the right Codecs with the PCX.
Best Regards
tgn
Post by tgn »
which ip boards are in use?intip2 or intip3 hardware?
regards...
Locked
Return to “AUDIOCODES”
