Zero Touch for OS6450 Instruction file
alcomint
Post by alcomint »
I am trying to configure zero touch scenario, I am trying to find a kind of template for "instruction file" and "configuration file" that how it looks like?
So far I am using such as
! Alcatel-Lucent OmniSwitch OS6450
! Firmware version
Firmware version:OS_6_7_1_R01
! Configuration file
Config filename:boot.cfg
! Primary File Server
Primary server:172.68.122.10
Primary protocol:TFTP
and it through some errors such as:
WED MAY 18 16:45:50 : REMOTE_CONFIG (125) info message:
+++ Firmware Version or its location is None. No Firmware to be downloaded
+++ Config file or its location is None. No Config File Downloaded
+++ Debug Filename or its location is None. No Debug File downloaded
+++ License Filename or its location is None. No License File downloaded
+++ Script file or its location is None. No Script File Downloaded
Kindly help me.
pstolpe
Re: Zero Touch for OS6450 Instruction file
Post by pstolpe »
Hi!
I have a successful template that looks like:
! Alcatel-Lucent OmniSwitch OS6450 – Instruction file version 0.1
! Firmware version
Firmware version:OS_6_7_1_45_R02
Firmware location:alcatel/image/OS6450_AOS_6.7.1.45_R02_GA
Config location:/
! Debug file
Debug filename:None
Debug location:None
! License Filename
License filename:lmlicense.dat
License location:/
! Script File
Script filename:script.txt
Script location:/
! Primary file Server
Primary server:192.168.0.10
Primary user:tftpuser
! Secondary file Server
Secondary server:None
Secondary protocol:None
Secondary user:None
I myself struggle to provition local users with this method.
Return to “OmniSwitch 6450”
