I had some problems with my Alcatel Omnistack LS 6248 switch.
After I ran delete startup-config and reboot the device, the equipament got stuck in MFG tests.
I can not get to the console CLI.
I can get to the startup menu and advanced menu. Already tried erasing the flash and updating the software image but got stuck to the same messages.
The console perfoms infinite MFG test:
________________________________________________________
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
Start MFG test
Waiting for Diagnostic Command
MFG will be activated after the system startup.
BOOT Software Version 1.0.0.12 Built 19-Oct-2006 09:07:37
OS6200 board, based on PPC8247
128 MByte SDRAM. I-Cache 16 KB. D-Cache 16 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
*** Running SW Ver. 1.5.1.9 Date 12-May-2008 Time 14:23:36 ***
HW version is 90.26.51
Base Mac address is: 70:72:cf:4e:d0:e0
Dram size is : 128M bytes
Dram first block size is : 98304K bytes
Dram first PTR is : 0x2000000
Flash size is: 16M
01-Jan-2000 01:01:04 %CDB-I-LOADCONFIG: Loading running configuration.
Enter number of MFG cycles to run (MFG infinite loop will start in 5 second):
* Start MFG Tests *
* Cycle number - 1 *
Host Tests.............................................START
Testing images checksum.....
Image1 Checksum Test..............................PASS
Internal Loopback UART test.......................PASS
Test Passed
Host Tests..............................................PASS
Please enter ESC for exit or any other key to continue
5
Power supply test......................................START
Power number 1 test passed.
Power number 2 not present.
Power supply test.......................................PASS
5 4 3 2 1
Fan test...............................................START
Fan number 1 test passed.
Fan number 2 test fail.
Fan test................................................FAIL
5 4 3 2 1
Internal Loopback......................................START
Internal loop test (max port rate + full duplex)........START
Setting ports configuration .............
LBack from ifIndex = g1, pkt# 100
LBack from ifIndex = g2, pkt# 100
LBack from ifIndex = g3, pkt# 100
LBack from ifIndex = g4, pkt# 100
LBack from ifIndex = e2, pkt# 100
LBack from ifIndex = e1, pkt# 100
LBack from ifIndex = e4, pkt# 100
LBack from ifIndex = e3, pkt# 100
LBack from ifIndex = e6, pkt# 100
LBack from ifIndex = e5, pkt# 100
LBack from ifIndex = e8, pkt# 100
LBack from ifIndex = e7, pkt# 100
LBack from ifIndex =e10, pkt# 100
LBack from ifIndex = e9, pkt# 100
LBack from ifIndex =e12, pkt# 100
LBack from ifIndex =e11, pkt# 100
LBack from ifIndex =e14, pkt# 100
LBack from ifIndex =e13, pkt# 100
LBack from ifIndex =e16, pkt# 100
LBack from ifIndex =e15, pkt# 100
LBack from ifIndex =e18, pkt# 100
LBack from ifIndex =e17, pkt# 100
LBack from ifIndex =e20, pkt# 100
LBack from ifIndex =e19, pkt# 100
LBack from ifIndex =e22, pkt# 100
LBack from ifIndex =e21, pkt# 100
LBack from ifIndex =e24, pkt# 100
LBack from ifIndex =e23, pkt# 100
LBack from ifIndex =e26, pkt# 100
LBack from ifIndex =e25, pkt# 100
LBack from ifIndex =e28, pkt# 100
LBack from ifIndex =e27, pkt# 100
LBack from ifIndex =e30, pkt# 100
LBack from ifIndex =e29, pkt# 100
LBack from ifIndex =e32, pkt# 100
LBack from ifIndex =e31, pkt# 100
LBack from ifIndex =e34, pkt# 100
LBack from ifIndex =e33, pkt# 100
LBack from ifIndex =e36, pkt# 100
LBack from ifIndex =e35, pkt# 100
LBack from ifIndex =e38, pkt# 100
LBack from ifIndex =e37, pkt# 100
LBack from ifIndex =e40, pkt# 100
LBack from ifIndex =e39, pkt# 100
LBack from ifIndex =e42, pkt# 100
LBack from ifIndex =e41, pkt# 100
LBack from ifIndex =e44, pkt# 100
LBack from ifIndex =e43, pkt# 100
LBack from ifIndex =e46, pkt# 100
LBack from ifIndex =e45, pkt# 100
LBack from ifIndex =e48, pkt# 100
LBack from ifIndex =e47, pkt# 100
|device|ifIndex| tx | rx | rx | rx |
| | | | good | wrong| no |
| 8 | g1 | 100 | 100 | 0 | 0 |
| 8 | g2 | 100 | 100 | 0 | 0 |
| 8 | g3 | 100 | 100 | 0 | 0 |
| 8 | g4 | 100 | 100 | 0 | 0 |
| 16 | e2 | 100 | 100 | 0 | 0 |
| 16 | e1 | 100 | 100 | 0 | 0 |
| 16 | e4 | 100 | 100 | 0 | 0 |
| 16 | e3 | 100 | 100 | 0 | 0 |
| 16 | e6 | 100 | 100 | 0 | 0 |
| 16 | e5 | 100 | 100 | 0 | 0 |
| 16 | e8 | 100 | 100 | 0 | 0 |
| 16 | e7 | 100 | 100 | 0 | 0 |
| 17 | e10 | 100 | 100 | 0 | 0 |
| 17 | e9 | 100 | 100 | 0 | 0 |
| 17 | e12 | 100 | 100 | 0 | 0 |
| 17 | e11 | 100 | 100 | 0 | 0 |
| 17 | e14 | 100 | 100 | 0 | 0 |
| 17 | e13 | 100 | 100 | 0 | 0 |
| 17 | e16 | 100 | 100 | 0 | 0 |
| 17 | e15 | 100 | 100 | 0 | 0 |
| 18 | e18 | 100 | 100 | 0 | 0 |
| 18 | e17 | 100 | 100 | 0 | 0 |
| 18 | e20 | 100 | 100 | 0 | 0 |
| 18 | e19 | 100 | 100 | 0 | 0 |
| 18 | e22 | 100 | 100 | 0 | 0 |
| 18 | e21 | 100 | 100 | 0 | 0 |
| 18 | e24 | 100 | 100 | 0 | 0 |
| 18 | e23 | 100 | 100 | 0 | 0 |
| 19 | e26 | 100 | 100 | 0 | 0 |
| 19 | e25 | 100 | 100 | 0 | 0 |
| 19 | e28 | 100 | 100 | 0 | 0 |
| 19 | e27 | 100 | 100 | 0 | 0 |
| 19 | e30 | 100 | 100 | 0 | 0 |
| 19 | e29 | 100 | 100 | 0 | 0 |
| 19 | e32 | 100 | 100 | 0 | 0 |
| 19 | e31 | 100 | 100 | 0 | 0 |
| 20 | e34 | 100 | 100 | 0 | 0 |
| 20 | e33 | 100 | 100 | 0 | 0 |
| 20 | e36 | 100 | 100 | 0 | 0 |
| 20 | e35 | 100 | 100 | 0 | 0 |
| 20 | e38 | 100 | 100 | 0 | 0 |
| 20 | e37 | 100 | 100 | 0 | 0 |
| 20 | e40 | 100 | 100 | 0 | 0 |
| 20 | e39 | 100 | 100 | 0 | 0 |
| 21 | e42 | 100 | 100 | 0 | 0 |
| 21 | e41 | 100 | 100 | 0 | 0 |
| 21 | e44 | 100 | 100 | 0 | 0 |
| 21 | e43 | 100 | 100 | 0 | 0 |
| 21 | e46 | 100 | 100 | 0 | 0 |
| 21 | e45 | 100 | 100 | 0 | 0 |
| 21 | e48 | 100 | 100 | 0 | 0 |
| 21 | e47 | 100 | 100 | 0 | 0 |
Internal Loopback.......................................PASS
5 4 3 2 1
Stress Test 10/Full....................................START
Stress Test 10/Full ......................START
Stress Test Pairs:
e1 e3 e5 e7 e9 e11 e13 e15 e17 e19 e21 e23 e25
e2 e4 e6 e8 e10 e12 e14 e16 e18 e20 e22 e24 e26
Stress Test Pairs:
e27 e29 e31 e33 e35 e37 e39 e41 e43 e45 e47 g1 g3
e28 e30 e32 e34 e36 e38 e40 e42 e44 e46 e48 g2 g4
Is it possible to restore the switch to normal function?
6428 Stuck in MFG Tests (manufacturing mode)
Re: 6428 Stuck in MFG Tests (manufacturing mode)
Never heard this function. Is it possible to interrupt the boot and go to startmenu? You have to press Enter ....
fueres
Yes, it is.
I can get to the startup menu and advanced menu (ctrl + shift + 6).
This MFG mode is something related to "manufacturing mode". I have no idea what it is.
But it seems to be a mode which the device got into.
Any help to get it to work again is really appreciated.
so it is time for a new switch ....
EightBup
6428 Stuck in MFG Tests manufacturing mode
I was loading the 93oct tune and somehow unplugged the cord as I was getting into the truck mid tune... now my I2030 is stuck in recovery mode and the back up will not load and truck won’t start. Please help I have to be at work by 9 in the morning and can’t figure this out
