Hello All,
Can someone please clear the air for me with the output below?.
1/1 imm12-10gb-xp-sf+ up provisioned 12
(not equipped)
When a card says provision as in above output, what is not equipped, IOM or MDA??.
Thanks,
Show card state
Re: Show card state
In the output, actually this is the same thing. The IMM card is an IOM and MDA built into a single card.
Technically the output is an MDA, so 1/1 would normally be just the daughter card, but here it would be both.
Hope this helps,
Cheers
Paramount
Hope this helps,
Cheers
Paramount
Eagleman
Re: Show card state
If I get you right, do you mean that the IOM/MDA is not equipped?.
Re: Show card state
Yep exactly that, the IMM in this case is not equipped so the slot is probably empty.
Cheers
Cheers
