WithdrawnIngVcLabel
gargoyle
WithdrawnIngVcLabel
Post by gargoyle »
anybody know what is wrong with this Flag?
show service id 50001001 all | match Flag
Flags : WithdrawnIngVcLabel
i found that RMTU & LMTU mismatch:
LMTU : 1500 RMTU : 1986
where i can config this MTU in order both MTU match?
Regarads,
mivens
Re: WithdrawnIngVcLabel
Post by mivens »
Try configuring the service-mtu.
The SAP MTU and path MTU for the associated SDP will also need to be big enough to carry those size frames.
gargoyle
Post by gargoyle »
hi mivens,
thanks a lot, it works,
the sample above i try in vpls, i just config the sdp on both node (no sap config).
but when i change the service type to epipe, the sdp become down with the same flag:
show router ldp bindings services service-id 50001001 detail
LDP Service FEC 128 Bindings
Type : E-Eth VcId : 50001001
SvcId : 50001001 SdpId : 5068
Peer Address : xxxxxxxx
Vc-switching : No
LMTU : 1986 RMTU : 1986
Egr. Lbl : 42529 Egr. Ctl Word : No
Egr. Flags : None Egr. Status Bits : N/A
Egr. Flow Label Tx : No Egr. Flow Label Rx : No
Egr. PW Status Sig : Disabled
Egr. Vccv CV Bits : lsp-ping
Egr. Vccv CC Bits : router-alert-label
Ing. Lbl : 253230W Ing. Ctl Word : No
Ing. Flags : Withdraw Ing. Status Bits : Supported (0x6)
Ing. Flow Label Tx : No Ing. Flow Label Rx : No
Ing. Wdraw Reason : localFault
Ing. PW Status Sig : Enabled
Ing. Vccv CV Bits : lsp-ping bfd-fault-detect
Ing. Vccv CC Bits : router-alert-label
that capture show "Ing. Wdraw Reason : localFault",
does that notification told because no sap configuration on that epipe?
the flag still same when RMTU and LMTU mismtach :
Many Thanks
Return to “7750 SR”
