Afternoon,
Im studying for the NRS II and have a lab environment configured using the Image /rel12.0/b1/r6
When I configure LDP over RSVPE-TE and use CSPF I get the following output for the CSPF calculated route:
ComputedHops:
172.16.0.150(S)
-> 172.16.0.149(SA)
-> 10.0.0.40(L)
Any idea's what the (SA) signifies for hop 172.16.0.149. I appreciate S is for strict and L is for loose but can't seem to find a reference for SA?
LDP over RSVP-TE
Re: LDP over RSVP-TE
From the output of show router mpls lsp path detail, the A flag designates an ABR if using Inter-Area Traffic Engineering.
There is example output in the Advanced Configuration Guide
*A:PE-1# show router mpls lsp "LSP-PE-1-PE-10" path detail
MPLS LSP LSP-PE-1-PE-10 Path (Detail)
Legend :
@ - Detour Available # - Detour In Use
b - Bandwidth Protected n - Node Protected
s - Soft Preemption
S - Strict L - Loose
A - ABR
Ynysmeudwy99
Thanks matey. Would help if I used my eyes
So when using ISIS as the IGP it identifies the L2 router (S) on the path?
Yes, if you are using ISIS as the IGP, the hops will be marked as strict or loose in the same way.
