4059EE Port unreachable
jigareda
Post by jigareda »
I have a problem when the creation a new attendant in OXE R11.1. I have created group and set to 4059EE. After that I have installed software 4059EE R1.6.17, Then I tried to connect and the process it did not complete, I attached the wireshark livecapture (unreachable port
). Any idea about this?
doublezero
Re: 4059EE Port unreachable
Post by doublezero »
Is this Trave in oxe or from PC? Maybe the firewall of PC or domain rule overwrites the local rule. Have you tried to start with right click start as administrator
Gesendet von meinem A0001 mit Tapatalk
jigareda
Post by jigareda »
Solved. I Have declared an associate set and It works fine.
Thanks for replay.
doublezero
Okay an easy solution
Return to “Attendant”
