HI
I have a potential power issue on site and trying to review the system logs.
My understanding is IF there is a power outage there is a 'last gasp message' which is stored within the switch can anyone direct me to where i can see these logs/messages.
Many thanks
SYSTEM LOGS
Re: SYSTEM LOGS
if there is a "normal" power down than there will be no file. If there is one crashdump or pmd-file you will find it direkt in /flash.
Re: SYSTEM LOGS
Hi Thank you for the reply.
After investigation i found no files, is there a command a can use to review the system logs ?
Re: SYSTEM LOGS
Re: SYSTEM LOGS
switch logs are in swlog-files.
> show log swlog
or
> show log swlog timestamp ?
> show log swlog
or
