DLT2 not working
wallacezammit
DLT2 not working
Post by wallacezammit »
I changed a PRA-T2 board to a DLT2 board by soldering together the citroen strap number 2 as shown in the documentation.
When plugged in the system is recognising there is a DLT2 board and it is also accepted.
But then in the access/trunks it is not shown. Also all Leds on the board remain switched off.
DO you have any idea if there is something else to do to get it to work?
Wallace
Krusty65
Re: DLT2 not working
Post by Krusty65 »
I might be wrong but the channels on a DLT2 are a licensed feature, also what slot do you have the card plugged into.
You might find some info if you go through the logs
K.
Return to “Configuration”
