OXO Compact Edition (R5) SW key problem
klodjan bregu
Post by klodjan bregu »
During initialisation, after defining basic configurations and system restart in the operator set is displayed "Software key problem". I have repeated the same action in another OXO Compact Edition and the situation was the same. Please can you help me to solve this problem.
Thanks in advance
Klodi
steve
Re: OXO Compact Edition (R5) SW key problem
Post by steve »
Check the software key in the OMC. (Modification typical / system / software key)
By default the order an OXOCE system without AIS (Alcatel Integration Service), the software key is missing from the system.
Also check the software release. (It must be same on the system and in the software key) Maybe release 6.0 is the right version for the software key. :!:
Return to “MAIN”
