Display entity name instead of User Name in user set
Ask your questions, regarding data or voice!
arpitb
Post by arpitb »
Hello Dears,
Actually i want to display entity name in called extension set instead of User extension number or User Name of Caller.
Please suggest, how can it is possible.
Thanks in advance
Re: Display entity name instead of User Name in user set
Put the entity instead of the user name on the user name
arpitb
Post by arpitb »
Sir, please understand what i want. Simply i want that, if i put entity number 1 in user configuration then its display Entity_1( entity name) in called extension and if i put entity number 2 then it display Entity_2( entity name). Please suggest.
arpitb
Post by arpitb »
Ok Sir,, thanks for your reply.
Return to “Pre-Sales”
