Hi!
I have a customer With a 4400 Oxe 9.1 that hasn't been logged on his 4760 for over 32 days. He now has the Declaration Node error Timoe out: 4760 server could not verify License corresponding to the declaration nord; too much time has elapsed.
I have tried to run a Complete Sync from "Directory" - "System". Still nothing.
Here is the log from NMCSyncLdapPbx_1.log:
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Start of Job (compl_synchro)
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Error: No Dn parent found for
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Notification to Loader : Taxa 4400(SynchroStarted)
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Notification to Loader : PTP (SynchroStarted)
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Notification to Loader : Taxa Alize(SynchroStarted)
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Notification to Loader : Taxa 4200(SynchroStarted)
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: Notification to Loader : (Loader/Voip/Load) IP ticket (SynchroStarted)
[8/2/2016 2:01:58 PM] 5704 SyncLdapPbx: SYNC_STARTED to loaders Notified
[8/2/2016 2:02:00 PM] 5704 SyncLdapPbx: Notification to Audit : Audit Information(SynchroStarted)
[8/2/2016 2:02:00 PM] 5704 SyncLdapPbx: SYNC_STARTED to Audit Notified
General Load: RetryPhasis=0 Request=2 CurrentSlice=1 TotalSLice=1
[8/2/2016 2:02:00 PM] 5704 SyncLdapPbx: The value of the attribute: pcsticketcollection = 1
[8/2/2016 2:02:00 PM] 5704 SyncLdapPbx: The value of the attributes: AuditProcess and MinOxeRelease = 0 and f5.401.14
[8/2/2016 2:02:05 PM] 4160 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : synchronizing_mib
[8/2/2016 2:02:06 PM] 4160 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : synchronized_mib
[8/2/2016 2:02:07 PM] 5704 SyncLdapPbx: Warning: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
Node '2' missing in subnetwork ' SubnetworkNumber=0, NetworkNumber=0, o=nmc'
[8/2/2016 2:02:11 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : reading Node
[8/2/2016 2:02:12 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : reading System_Parameters
status_sync : reading system_option
[8/2/2016 2:02:13 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : reading Broadcast
[8/2/2016 2:02:14 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : reading Network_Node
[8/2/2016 2:02:15 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : complete_load
[8/2/2016 2:02:16 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : reading SCS_Addresses
[8/2/2016 2:02:21 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : reading Subscriber
[8/2/2016 2:02:23 PM] 4960 SyncLdapPbx: running (50) ...
[8/2/2016 2:02:25 PM] 4960 SyncLdapPbx: running (100) ...
[8/2/2016 2:02:27 PM] 4960 SyncLdapPbx: running (150) ...
[8/2/2016 2:02:29 PM] 4960 SyncLdapPbx: running (200) ...
[8/2/2016 2:02:31 PM] 4960 SyncLdapPbx: running (250) ...
[8/2/2016 2:02:32 PM] 4960 SyncLdapPbx: running (300) ...
[8/2/2016 2:02:34 PM] 4960 SyncLdapPbx: running (350) ...
[8/2/2016 2:02:36 PM] 4960 SyncLdapPbx: running (400) ...
[8/2/2016 2:02:37 PM] 4960 SyncLdapPbx: running (450) ...
[8/2/2016 2:02:41 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : auditing
[8/2/2016 2:02:43 PM] 4960 SyncLdapPbx: Software download not enabled in LDAP
[8/2/2016 2:02:43 PM] 4960 SyncLdapPbx: Audit Process is not Enabled or No Audit License
[8/2/2016 2:02:43 PM] 4960 SyncLdapPbx: pbxDn:SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc
status_sync : loaded
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Notification: Filter 4 updated
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Setting notification filter: '\\7::\'PBX\'\\8::\'OXE\'\\89::\'Node1\'' ~ $objectHierarchy
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Notification to Loader : Taxa 4400(SynchroStopped)
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Notification to Loader : PTP (SynchroStopped)
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Notification to Loader : Taxa Alize(SynchroStopped)
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Notification to Loader : Taxa 4200(SynchroStopped)
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: Notification to Loader : (Loader/Voip/Load) IP ticket (SynchroStopped)
[8/2/2016 2:02:44 PM] 5704 SyncLdapPbx: SYNC_STOPPED to Loaders Notified
[8/2/2016 2:02:46 PM] 5704 SyncLdapPbx: Notification to Audit : Audit Information(SynchroStopped)
[8/2/2016 2:02:46 PM] 5704 SyncLdapPbx: SYNC_STOPPED to Audit Notified
[8/2/2016 2:02:46 PM] 5704 SyncLdapPbx: End of Job (compl_synchro)_
Restricted Mode on 4760, Timeout... HELP?
Re: Restricted Mode on 4760, Timeout... HELP?
I have old TC for 4760 - chapter 3.4.1 and 3.4.2 - may be this info can help you.
redlabel
Thanks Vad.
Looks like I have a FTP login issue?
[03.08.2016 13:43:07] 5200 LicServer: Program starting...
[03.08.2016 13:43:08] 5200 LicServer: Signature in license file is OK
[03.08.2016 13:43:08] 5200 LicServer: time for last synchronization of LDAP server with all networks: 3 minutes (0 days)
[03.08.2016 13:43:08] 5200 LicServer: time since last PBX key control: 67682 minutes (47 days)
[03.08.2016 13:43:08] 5884 LicServer: Program is running
[03.08.2016 13:43:08] 5884 LicServer: Upgrading Display List...
[03.08.2016 13:43:10] 5884 LicServer: Display List upgrade is done.
[03.08.2016 13:43:10] 5884 LicServer: Upgrading Display Attributes...
[03.08.2016 13:43:10] 5884 LicServer: Display Attributes upgrade is done.
[03.08.2016 13:43:10] 5884 LicServer: Upgrading Grid groups...
[03.08.2016 13:43:11] 5884 LicServer: Grid group upgrade is done.
[03.08.2016 13:43:11] 5884 LicServer: Upgrading Search List...
[03.08.2016 13:43:11] 5884 LicServer: Search list upgrade is done.
[03.08.2016 13:43:11] 5884 LicServer: Upgrading Search classes...
[03.08.2016 13:43:12] 5884 LicServer: Search classes upgrade is sucessfull.
[03.08.2016 13:43:12] 5884 LicServer: Counting pcx and subscribers...
[03.08.2016 13:43:12] 5884 LicServer: Subscribers pcx and subscribers count is sucessfull.
[03.08.2016 13:43:12] 5884 LicServer: pcxnumber : percent of max subscriber: 1/10000 = 0% (status=ok)
[03.08.2016 13:43:14] 5884 LicServer: configuration : percent of max subscriber: 482/550 = 87% (status=warning)
[03.08.2016 13:43:14] 5884 LicServer: Error: InternalAlarm DLL : Persistent problem while sending alarm.
[03.08.2016 13:43:14] 5884 LicServer: Error: SendInternalAlarm(4000) failed...
[03.08.2016 13:43:15] 5884 LicServer: Checking key of PBX 'SubnetworkNodeNumber=1, SubnetworkNumber=0, NetworkNumber=0, o=nmc'...
[03.08.2016 13:43:15] 5884 LicServer: Error: FtpLogin(158.39.76.227,adfexc) failed...
[03.08.2016 13:43:15] 5884 LicServer: Error: EXCEEDED
Checking time since last PBX key control: too many days whithout control (maximum allowed : 32)!
Days for last control: 47
Check connectivity with PBX.
[03.08.2016 13:43:53] 6000 LicServer: Processing a client lock request...
[03.08.2016 13:43:53] 6000 LicServer: Client lock request accepted lock id = 380370944
[03.08.2016 13:43:53] 6000 LicServer: Client lock 1/1 = 100%
[03.08.2016 13:52:17] 5884 LicServer: Counting pcx and subscribers...
[03.08.2016 13:52:18] 5884 LicServer: Subscribers pcx and subscribers count is sucessfull.
[03.08.2016 13:52:18] 5884 LicServer: pcxnumber : percent of max subscriber: 1/10000 = 0% (status=ok)
[03.08.2016 13:52:18] 5884 LicServer: configuration : percent of max subscriber: 482/550 = 87% (status=warning)
[03.08.2016 14:02:20] 5884 LicServer: Counting pcx and subscribers...
redlabel
I can't seem to get this sync up and running again. Any more tips?
