we have patched 2 systems at a customer from k152034a to k152044. After that the attendants have some problems.
After the start in the morning all is fine. Then suddenly the pbx receives a incident:
08/08/16 07:57:51 000001M|004/00/0/070|=3:1317=Inconsistency on button 1 of attendant 0.The programmed key 1 is the normal call presentation key.
One node has one 4059 attendant, the other has two 4059 attendant.
My Question: Have you a system with k152044 and a 4059 attendant which is working fine?
