Can not console into omniswitch
mrtq86
Post by mrtq86 »
Hi all,
I had config my switch with vlans and dhcpd.conf, but now can not connect it, because my switch always restart. Maybe it error operation system.
The current date and time is:
Coordinated Universal Time (UTC): SUN DEC 31 01:28:39 2000
Local time: SUN DEC 31 01:28:39 2000 UTC
Starting dynamic software load from '/flash/certified/'...
FIPS_text_start() returns NULL
SUN DEC 31 01:28:49 : SYSTEM (75) info message:
+++ Switch Logging device '/dev/console' enabled for output
SUN DEC 31 01:28:49 : CSM-CHASSIS (103) info message:
+++ == CSM == === Chassis Supervision Starting Up ===
sysStartWatchdog() Starting watchdog timer to INTERRUPT after 240 secs.
SUN DEC 31 01:29:29 : CSM-CHASSIS (103) info message:
+++ == CSM == APP MONITORING ON
+++ == CSM == ===== THIS STACK(1) IS PRIMARY =====
SUN DEC 31 01:29:37 : HSM-CHASSIS (101) info message:
+++ T1:Ni Insertion detected on slot 1
SUN DEC 31 01:29:38 : HSM-CHASSIS (101) info message:
+++ ==== HSM === Power Supply 1 is OPERATIONAL
SUN DEC 31 01:29:58 : WEB (69) info message:
+++ WebView SSL/RSA file-based certificate set-up successful!
SUN DEC 31 01:30:02 : DHCP-SERVER (140) info message:
+++ /flash/switch/dhcpd.conf processed with 4 subnets
 Dumping PMD.....
tCsCSMtask2 (0) @ 1538479026 READY lckd=2041731515 Flags:  C      Mode:SVC32stk 5bbb73b3-5bba58bb
(d4d4de0)   2e99d4 vxTaskEntry +1c: csCsmSupervisorMain()
(d4d4dc8)  13c2574 csCsmSupervisorMain +24: csCsmHeartbeatChecking()
(d4d4c78)  13c2118 csCsmHeartbeatChecking +2cc: cs_Reboot()
(d4d4c38)  13beebc cs_Reboot +1bc: pmdDump()
(d4d4c0c)   14fcac pmdDump +68: taskRegsInit()
Please tell me how to upgrade operation system?
Best regard!
Re: Can not console into omniswitch
you will find some explanations here in the forum (same for 6250 and 6450).
f.e. viewtopic.php?f=329&t=22616&p=83296&hil ... 450#p83296 or viewtopic.php?f=394&t=23437&p=84179&hil ... 450#p84179
mrtq86
Post by mrtq86 »
silvio wrote:Hi,
Hi Silvio,
I've got a OS6250 -24 switch that is doing this:
Dumping PMD.....
tCsCSMtask2 (0) @ 1504860594 READY lckd=1504860594 Flags:  C      Mode:SVC32stk 59b259b2-59b259b2
====> External interrupts stats <====
WD int count : 0
CPLD system intr cnt : 0
EXP mod intr cnt : 0
PWR fail int cnt : 0
Combo phy intr cnt : 4
Combo rxLoss intr cnt : 0
Writing PMD to flash ...size 308bytes and block 0
Writing PMD to flash ...size 725bytes and block 0
Writing PMD to flash ...size 1231bytes and block 0
Writing PMD to flash ...size 1442bytes and block 0
Writing PMD to flash ...size 8173bytes and block 0
Writing PMD to flash ...size 8236bytes and block 0
Writing PMD to flash ...size 8302bytes and block 0
Writing PMD to flash ...size 9652bytes and block 0
Writing PMD to flash ...size 34054bytes and block 0
Writing PMD to flash ...size 34554bytes and block 0
Writing PMD to flash ...size 38618bytes and block 0
Writing PMD to flash ...size 64647bytes and block 0
Writing PMD to flash ...size 131060bytes and block 1
Writing PMD to flash ...size 262132bytes and block 2
Writing PMD to flash ...size 370691bytes and block 2
Dumping sys trace to PMD
Writing PMD to flash ...size 393204bytes and block 3
Writing PMD to flash ...size 476455bytes and block 3
Dumping ttall to PMD
Writing PMD to flash ...size 524276bytes and block 4
Writing PMD to flash ...size 568962bytes and block 4
Dumping application data to PMD
  2e99e0 vxTaskEntry                   + 28: ipedrMain ()
 1b5f5e0 ipedrMain                     +1b8: semQPut ()
  2e99e0 vxTaskEntry                   + 28: ipedrKernelMsg ()
 1b81b64 ipedrKernelMsg                + 4c: msgQReceive ()
  37e288 msgQReceive                   +104: qJobGet ()
  2e99e0 vxTaskEntry                   + 28: ipedrRxPkt ()
 1b7deb4 ipedrRxPkt                    + 38: msgQReceive ()
Writing PMD to flash ...size 655348bytes and block 5
Writing PMD to flash ...size 698894bytes and block 5
Dumping spy report to PMD
Writing PMD to flash ...size 709649bytes and block 5
Completed PMD dump system rebooting...
AOS BootSelector Version: 6.6.3.259.R01
Creation Date: Mar 21 2012 23:07:59.
Press x to choose XMODEM...
Press s to STOP AT MINIBOOT...
Reading kfminiboot.bs from /boot ...done:
1466043
Uncompressed kfminiboot.bs @ 0xA10000...
Running Miniboot...
Detected board DB-98DX4122-48G
Ctrl env init... Done.
CPU if init..... Done.
Done. Actual freq = 96153Hz
Memory on board initialized .
Init Phy port 0 .. Done
Init Phy port 1 .. Done
Power up GMII port0 .. Done.
Power up GMII port1 .. Done.
Detected DRAM size 256MB
Detect SysClk  320MHz
Detect Tclk    200MHz
Marvell Controller initialization Done.
Eth int Ctrl.... Done
GPIO int Ctrl... Done
PEX int Ctrl.... Done
PEX0 init....... Done. DEVICE type selected
USB Init........ Done
USB int Ctrl.... Done
XOR int Ctrl.... Done
XOR init........ Done
mvCtrlInit2..... done
PCI auto config. done
sysHwInit2...... DoneUSB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD  Wind River Systems, Inc. 560 Initialized
Non-PCI USB device found: pgmIf=0xa0, idx=0 , baseAddr=0xf1050100, irq=19, swapFunc=0xa1abf4
EHCI Controller found.
Waiting to attach to USBD...Done.
0xffffe50 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
CS EEPROM Module ID: 420122a1 , System type: SMB 24 copper ports with stacking - Kingfisher
System Configuration
BSP Ver: 1.2/1.1.01   Creation date: May  5 2013, 23:39:51
CHIP   : MV88F6281 Rev 2
CPU    : ARM926 (Rev 1)
BOARD  : DB-98DX4122-48G (0x7)
CLOCKs : tClk =  200 MHz, sysClk =  320 MHz
         pClk =  800 MHz
NAT_SUPPORT         = Disabled
VFP_SUPPORT         = Disabled
Target Name: vxTarget
Ethernet port #0 initialized
mgi0 Interface Loaded
mgi0 Interface Started
mgi0 Interface - Link Up, 1000 Full
Attaching network interface lo0... done.
Adding 8078 symbols for standalone.
Boot parameters are:
 'flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin pw=switch cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.6.4.158.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on May  5 2013, 23:39:51.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5.  Processor #0.
Memory Size: 256 MBytes.  BSP version 1.2/1.1.01.
Portions of code copyrighted by Agranat Systems, Inc.  All Rights reserved
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2013.  All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999.  All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991.  All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000.  All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999.  All Rights reserved
Portions of code copyrighted by RSA Security, Inc.  All Rights reserved
Portions of code copyrighted by Sun Microsystems, Inc.  All Rights reserved
Portions of code copyrighted by Wind River Systems, Inc.  All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
Transferring crash data to a file  ...
length of pmd data 0xad411
Transferring PMD done...
Attempting to load from the CERTIFIED directory...
Loading kernel from '/flash/certified/KFos.img'...
7228096
Loade
Detect Tclk    200MHz
Non-PCI USB device found: pgmIf=0xa0, idx=0 , baseAddr=0xf1050100, irq=19, swapFunc=0x10abf4
BSP Ver: 1.2/1.1.01   Creation date: May 24 2013, 22:25:06
         pClk =  800 MHz
Write Protecting exception Vectors
 Write protecting KFos .text sections (0x100000 to 0x526000)  1062 pages
Adding 11939 symbols for standalone.
AOS kernel version: 6.6.4.177.R01
Made on May 24 2013, 22:25:06.
Coordinated Universal Time (UTC): SUN DEC 31 06:51:44 2000
Local time: SUN DEC 31 06:51:44 2000 UTC
SUN DEC 31 06:51:54 : SYSTEM (75) info message:
SUN DEC 31 06:51:54 : CSM-CHASSIS (103) info message:
SUN DEC 31 06:52:34 : CSM-CHASSIS (103) info message:
SUN DEC 31 06:52:41 : HSM-CHASSIS (101) info message:
SUN DEC 31 06:52:43 : HSM-CHASSIS (101) info message:
SUN DEC 31 06:53:03 : WEB (69) info message:
SUN DEC 31 06:53:07 : DHCP-SERVER (140) info message:
after that, it restart again.
you can open a ticket at alcatel for it. Or you can try to update the switch via USB - sometimes this helps to "repair" the switch. For more analysis you have to open a ticket.
mrtq86
Post by mrtq86 »
silvio wrote:you can open a ticket at alcatel for it. Or you can try to update the switch via USB - sometimes this helps to "repair" the switch. For more analysis you have to open a ticket.
Thanks for your help!
Return to “OmniSwitch 6250”
