OS6450-48 switch will not boot
acshearer
Post by acshearer »
Hello All,
I have an OS6450-48 port switch where it powers up but only the PWR led light shows and the boot process stops and hangs. Below is the boot process. Is there anything I can do to get this back and working?
Andrew
Network Administrator
AOS BootSelector Version: 6.6.3.259.R01
Creation Date: Mar 21 2012 23:07:59.
Press x to choose XMODEM...
Press s to STOP AT MINIBOOT...
S Key was pressed
Reading kfminiboot.bs from /boot ...done:
1572800
Uncompressed kfminiboot.bs @ 0xA10000...
Running Miniboot...
Detected board DB-98DX4122-48G
Ctrl env init... Done.
CPU if init..... Done.
Done. Actual freq = 96153Hz
Memory on board initialized .
Init Phy port 0 .. Done
Init Phy port 1 .. Done
Power up GMII port0 .. Done.
Power up GMII port1 .. Done.
Detected DRAM size 256MB
Detect SysClk 320MHz
Detect Tclk 200MHz
Marvell Controller initialization Done.
Eth int Ctrl.... Done
GPIO int Ctrl... Done
PEX int Ctrl.... Done
PEX0 init....... Done. DEVICE type selected
USB Init........ Done
USB int Ctrl.... Done
XOR int Ctrl.... Done
XOR init........ Done
mvCtrlInit2..... done
PCI auto config. done
sysHwInit2...... DoneUSB2 Host Stack Initialized.
USB Hub Driver Initialized
USBD Wind River Systems, Inc. 560 Initialized
Non-PCI USB device found: pgmIf=0xa0, idx=0 , baseAddr=0xf1050100, irq=19, swapFunc=0xa1abf4
EHCI Controller found.
Waiting to attach to USBD...Done.
0xffffe50 (tRootTask): usbBulkDevInit() returned OK
usbCbiUfiDevInit() returned OK
CBI Class Driver Successfully Initialized
CS EEPROM Module ID: 420123b8 , System type: 6450 48 copper ports, 2 fixed sfp+ ports and 1 SFP+ Expansion Module in STACKING MODE - Kingfisher2
System Configuration
BSP Ver: 1.2/1.1.01 Creation date: Mar 22 2012, 00:07:53
CHIP : MV88F6281 Rev 2
CPU : ARM926 (Rev 1)
BOARD : DB-98DX4122-48G (0x7)
CLOCKs : tClk = 200 MHz, sysClk = 320 MHz
pClk = 800 MHz
NAT_SUPPORT = Disabled
VFP_SUPPORT = Disabled
FlashFX initialization required 816ms
File System initialization required 0ms
FlashFX initialization required 99ms
Target Name: vxTarget
Ethernet port #0 initialized
mgi0 Interface Loaded
mgi0 Interface Started
mgi0 Interface - Link Up, 1000 Full
Attaching network interface lo0... done.
Adding 8031 symbols for standalone.
Boot parameters are:
'flash(0,0)cmm:default e=10.4.50.165:ff000000 g=10.4.50.5 u=admin pw=switch f=0x1000 cb=9600 cp=none cs=1 cw=8 cm=modemControlOff'
AOS miniboot version: 6.6.3.259.R01
VxWorks (for DB-98DX4122-48G BE MMU ARCH 5) version VxWorks5.5.1
KERNEL: WIND version 2.6
Made on Mar 22 2012, 00:07:53.
Copyright Wind River Systems, Inc., 1984-2006
CPU: DB-98DX4122-48G BE MMU ARCH 5. Processor #0.
Memory Size: 256 MBytes. BSP version 1.2/1.1.01.
Portions of code copyrighted by Alcatel Internetworking, Inc. 1994-2012. All Rights reserved
Portions of code copyrighted by Apptitude, Inc. 1997-1999. All Rights reserved
Portions of code copyrighted by Free Software Foundation, Inc. 1989,1991. All rights reserved
Portions of code copyrighted by The OpenLDAP Foundation 1999-2000. All rights reserved
Portions of code copyrighted by Theodore T'so 1994,1995,1996,1997,1998,1999. All Rights reserved
Portions of code copyrighted by RSA Security, Inc. All Rights reserved
Portions of code developed by the Carnegie-Mellon University.
Return to “OmniSwitch 6450”
