Does anyone can help me and descriptions HDD replacement procedure on CS OXE R.11.0.
I have duplicate processors, on a single HDD is broken, how can I replace, what should you do?
Thank you
Re: HDD replacement procedure on CS
Install as new, define as backup and then do a mastercopy
So I put in a new HDD following the CS, without formatting and installing the OS, i do mastercopy OXE be fully cloned HDD?
As said, install as new, you then define IP address and basic settings as new installation. Then do a mastercopy
Never said clone
Never said clone
As Cavagnaro sad:
- put new HDD
- download SW (R11.0, the same patch as on worked CS)
- make netadmin (declare IP addresses - own and second CS)
- copy all netadmin setting (netadmin -m/ copy setup/ copy from twin CPU)
- do mastercopy with swinst (expert menu/ CPU cloning/Cloning database - select all except Linux data) .
- put new HDD
Thank you very much, gentlemen!
