Add IAP 205
gjortega
Add IAP 205
Post by gjortega »
Hi, I'm trying to implement a full Unified Access laboratory (wired and wireless) through the Omnivista 2500 but currently I can only add switches to the OV. Is there a way to add wireless devices in order to send the UNPs to them?
I'm using Omnivista 2500 V4.2.1 R01
I have an Alcatel IAP 205.
Thanks in advance
Re: Add IAP 205
you can add also the IAP to OV (I do this in my installation). But I haven't done test with UNP and IAP.
In the OV guide I find this:
The Unified Policies Device Selection Screen is used to select the switches to which you want to apply the Policy. Select an option (Use Switch Picker/Use Topology), and select the device(s). Click on the Next button at the bottom of the screen or click on Set Condition on the left side of the screen to move to the next step. If necessary, you can also click the Back button to return to the screen and add/delete devices.
Note: In Expert Mode, you can only select AOS Devices for Policy creation. However, you can select wireline and wireless devices when creating Unified Policies. Also note that you cannot select IAP Devices when creating Unified Policies.
But at Unified Access it should be possible (but never tested).
gjortega
Re: Add IAP 205
Post by gjortega »
Thanks for the reply Silvio.
How do I add the IAP to the OV? Do I need the MIB files? In case I need the MIB files, where can I find them? I was looking for them with no luck.
Re: Add IAP 205
you didn't need any MIBs.
Make in your IAP your SNMP-setting (f.e. for create a snmp v3 user). In OV make discover with this credentials for the specific ip range (or add a single device).
Return to “OmniVista 2500 v3.5”
