Interface not pinging over VPRN services_ SR#07
hbaloi
Post by hbaloi »
Hello firends,
I configured two VPRN services ( svc id 2 ) , on two site routers ( TDM and Mcel ) , to test de vrrp funcionality. But im im not able to ping the adjacent router interface .
This one was configured under VPLS services ( svc id 11 ) .
*A:TDM# configure service vprn 2
*A:TDM>config>service>vprn# info
autonomous-system 65001
route-distinguisher 10.1.16.127:2
auto-bind mpls
vrf-target target:65001:2
interface "to_BSC" create
address 10.217.33.2/29
icmp
no redirects
exit
bfd 100 receive 100 multiplier 3
vrrp 1
backup 10.217.33.1
priority 200
no preempt
ping-reply
bfd-enable 2 interface "to_BSC" dst-ip 10.217.33.3
exit
vpls "to_BSC"
exit
exit
no shutdown
A:Mcel>config>service>vprn# info
route-distinguisher 10.1.16.126:2
auto-bind mpls
address 10.217.33.3/29
icmp
no redirects
exit
vrrp 1
backup 10.217.33.1
priority 200
no preempt
ping-reply
bfd-enable 2 interface "to_BSC" dst-ip 10.217.33.2
exit
vpls "to_BSC"
exit
exit
no shutdown
Stoffen
Re: Interface not pinging over VPRN services_ SR#07
Post by Stoffen »
Hi.
Is the VPLS configuration OK?
Do you see mac-adresses from both nodes in the VPLS on both nodes?
Are all services up?
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
hbaloi
Post by hbaloi »
Hi Stoffen,
Sharing the VPLS configs on both routers. I cant see the mac-adresses from both nodes .
A:Mcel>config>service>vpls# info
description "to_BSC"
allow-ip-int-binding
split-horizon-group "SHG" create
exit
stp
no shutdown
exit
service-name "to_BSC"
sap 1/1/3 create
exit
mesh-sdp 1271:11 create
no shutdown
exit
no shutdown
zeips
Post by zeips »
I would check vprn route table first. You can add loopback iface on both nodes under vprn-s and see if you can ping one another. Don't forget about export policies. If this works then move to rvpls troubleshooting.
hbaloi
Post by hbaloi »
Hello can you share how to add it ...
zeips
Post by zeips »
/configure service vprn 2 interface 'x' loopback
but you can actually ping router 2 10.217.33.3 source 10.217.33.2 from TDM
hbaloi
Post by hbaloi »
Hi Zeips,
Still not able to ping . Also i dont know if the looback is correctly configured .
*A:TDM# ping router 2 10.217.33.3 source 10.217.33.2
PING 10.217.33.3 56 data bytes
Request timed out. icmp_seq=1.
Request timed out. icmp_seq=2.
Request timed out. icmp_seq=3.
---- 10.217.33.3 PING Statistics ----
5 packets transmitted, 0 packets received, 100% packet loss
*A:TDM# show router 2 arp
ARP Table (Service: 2)
IP Address MAC Address Expiry Type Interface
10.217.33.1 00:00:5e:00:01:01 00h00m00s Oth to_BSC
10.217.33.2 da:00:ff:ff:ff:49 00h00m00s Oth to_BSC
10.217.33.3 04h00m00s Dyn to_BSC
10.217.33.10 00h00m00s Oth looback
No. of ARP Entries: 4
*A:TDM#
hbaloi
Post by hbaloi »
A:Mcel# show router 2 arp
10.217.33.2 04h00m00s Dyn to_BSC
10.217.33.3 da:00:ff:ff:ff:49 00h00m00s Oth to_BSC
10.217.33.9 00:17:b4:6f:df:04 00h00m00s Oth looback
A:TDM#
10.217.33.10 00:17:b4:91:c5:04 00h00m00s Oth looback
hbaloi
Post by hbaloi »
A:TDM#
zeips
Post by zeips »
Can you check this topic and verify:
viewtopic.php?t=21075
Return to “7750 SR”
