Hi:
I have some dect users and I would like for internal incoming calls send DTMF codes without dial prefix, is possible ???
Thanks in advance
Automatic DTMF for incoming calls
- frank
Re: Automatic DTMF for incoming calls
You do not control incoming calls DTMF.
Unless if you consider an incoming call one of your extensions calling one of your services ?
Hi Frank:
Thanks for your reply.
Very easy, I have an alarm system connected to OxE with analog users, when there is an alarm the system call to users dects, the users dects has to validate the alarm dialing a digits DTMF, I woul like to avoid dial the prefix internal for DTMF in OxE and dial directly the codes for validate the alarm.
- frank
Have you tried VSI Transparency in the Analog user settings ?
Hi Frank:
Modified in the analog user and working !!!!!
Thanks for your help.
Kind regards
Kind regards
