Recovery of cold reset OmniPCX
Osqa
Post by Osqa »
Hi all,
I by mistake did a cold reset of our work OmniPCX.
I need to get it back running ASAP but have no idea where to start from.
I have a backup file of its database but i can no longer access it on its old IP. I have checked my DHCP logs and I don't find any assignments.
Help needed.
Re: Recovery of cold reset OmniPCX
I think - now you have default IP address - 192.168.92.246. Assign to PC compatible IP address (f.e. 192.168.92.1 255.255.255.0) and try to connect.
Return to “System”
