Delete voice message before it's completly listened ?
nozil
Post by nozil »
Is the any option to do this ?
It's very annoying to have to listen the whole message berfore
being able to delelte it, even if this msg had already been listened once
hendersonla
Skip Listening to vmail
Post by hendersonla »
You can press 33 to go straight to the end while listening to the message and then 7 to delete.
CoastHills
Voicemail
Post by CoastHills »
3 = forward 10 seconds
next 3 = forward to end
7 = delete message
You can also use the pound sign to bypass greetings and help messages.
nozil
Post by nozil »
Great works fine. By the way, do you have any menucard that lists all
the codes usable with this voice mail system ?
Return to “Voicemail (46x5)”
