The Service Mode button (gear icon) is greyed out on the screen and I cannot get it back.
Anyone?
4059 sevice mode button greyed out
Re: 4059 sevice mode button greyed out
Check the configuration of the attendant rights in the OXE system.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
ACSE OXE R12.1
The guide / service buttons get enabled on successful download of oxe g/s definition files. You see this file download on application start (the progress bar in the bottom status bar).
Sometimes the oxe end the download sequence prematurely, causing the entire guide/service mode to fail. Without these definition files the g/s mode can't function hence the disabled state. Often a bascul/reboot solves the problem.
/B
Sent from my iPad using Tapatalk
/B
-: I also have a UDP joke, but you might not get it :-
macarui
We have the same problem. A bascul solves the problem. Thanks!
