forbidden forward operation internal
sale_phukientongdai
Hi All
I have using OXE system and now i have try to used prefix for forward and User/Dynamic State to try to internal forward but not success, it is display with "forbidden forward operation" on the mgr
I have tried to check Phone COS and the forwards are enable (set to 1)
The user set to external forward work fine
Please help
Please help
Re: forbidden forward operation internal
Check phone feature COS for forward destination set (if prefix forward+number or User/Dynamic State not work) - item Protected against forwarding.
sale_phukientongdai
This system had ready to config
Immediate forward : 1 x
x Immediate forward on busy : 1 x
x Forward on no reply : 1 x
x Forward on busy or no reply : 1 x
x Forward cancellation : 1 x
x Forward cancel.by destinat. : 1 x
x Overfl.no reply on associate : 1 x
x Cancel Overfl.on associate : 1 x
x Set group exit : 1 x
x Set group entry : 1
Please give me some idea
Repeat one more time - if for user A forbidden - Immed fwd prefix + internal number B.
Check phone feature COS for User B - item Protected against forwarding.
sale_phukientongdai
Both user A and B using same phone COS and we have not tick on Protected against forwards
Please help
Please help
User B (forward destination) - not in DND state or forward? Not used multicompany (short local numbering plan)? User A can call user B?
not work - when dial prefix+number (I hope after fwd prefix user not dial TG seizure prefix before number as for ext fwd)?
not work - when manage dynamic state user (for user A) - forward for primary number=immediate, destination=user B (just user B, not fwd_prefix+user B)?
Additional question - user A and B - usual analogue/digital/IP/DECT? Not SIP set (or IP DECT set).
is user b maybe forwarded to user a? you cannot forward in a loop
sale_phukientongdai
After i reinstall software and config again, everything are OK
Thank to all
Thank to all
