sorry the memory is full
trentq
Post by trentq »
Hi All
I a problem just started when someone calls in our main number after hours, instead of getting the after hours message and voicemail, they just hear 'sorry the memory is full' over and over again.
Does anyone know where to look to fix this?
Cheers
T
Re: sorry the memory is full
Main number, after hours message, calls - IAA/AA? Calls - internal/external? Some info about your system and management will be good (I forgot my magic ball at home).
May be - your VM mail box - full.
trentq
Post by trentq »
It is incoming calls from outside. the number is a call queue. Its an OmniPCX device. I use the OMC program to manage. I don't know the system very well that's is why I came here for help.
Topic was moved - because your PBX - not OmniPCX Enterprise (OXE) but OmniPCX Office OXO).
trentq
Post by trentq »
ok thanks, is anyone able to assist me please?
alexeik
Post by alexeik »
seems a full mailbox...
you can check with omc
-> voice processing -> statistic
Tab mailboxes
trentq
Post by trentq »
thank you for replying, that tab shows 0 messages
alexeik
Post by alexeik »
then its hard to guess... ask your partner who sold the pbx...
Return to “Beginner's questions about the OmniPCX OFFICE”
