OmniSwitch 6850 Help needed, cant access via CLI
aldocano
Post by aldocano »
Hello everyone, recently i bought an used OmniSwitch 6850 but i have problems on accessing the switch via cli, im using a cisco console cable on com port and cant get any response from the switch i need to reset it to defaults from the previous configurations which i dont have any idea how to access it or how it might be configured.
Any help will be helpful. Thanks in advance.
Re: OmniSwitch 6850 Help needed, cant access via CLI
the adapter is different to cisco. In this forum you will find a lot of hints for it (it is the same for all omniswitches).
