Hi All
is it possible to do have a power fail cut through on a PRA-T2 card ? If so, what do I need to do set it up ? If not through the OXO itself, what would I need to provide the facility to my system ?
Thanks for any advice.
Power Fail Cut Through on PRA-T2 card
Jigger
Re: Power Fail Cut Through on PRA-T2 card
What do you mean by cut through?
If you mean you have had a power fail and now the PRA-T2 is not working, you will most likley need to replace it.
roly@rbmit.com.au
[quote="Jigger"]What do you mean by cut through?
If you mean you have had a power fail and now the PRA-T2 is not working, you will most likley need to replace it.[/quote]
Same as the PFCT (Power Fail Cut Through) on the AMIX cards. In the event of a power failure all inbound calls get routed to a particular port so you still have some functionality.
- tot3nkopf
Not possible through Alcatel PBX.
Regards.
Regards.
roly@rbmit.com.au
tot3nkopf wrote:Not possible through Alcatel PBX.
Regards.
Thanks for the confirmation - I couldn't see any mention of it in the Expert Documentation.
Is there an external solution that I might be able to look at ?
Jigger
Sorry bud, didnt read your post very well at all... Just so used to giving those kinds of answers...roly@rbmit.com.au wrote:Same as the PFCT (Power Fail Cut Through) on the AMIX cards. In the event of a power failure all inbound calls get routed to a particular port so you still have some functionality.Jigger wrote:What do you mean by cut through?
Again, my bad! Ciao
