Voice guide
seetharam r
Voice guide
Post by seetharam r »
Dear all,
I have a hotel customer.
After check in if anyone leaves msg to the guest it plays you have a voicemail to consult press 5 but it has been consulted but still everytime when guest picks the handset it plays the above msg.
Help me.......Critical situation.
HUSSAINQCS
Re: Voice guide
Post by HUSSAINQCS »
This is happening for only particular user or all user
HUSSAINQCS
Re: Voice guide
Either they not consulted properly or you have to consult all the voicemail and give a try what is the parameter option is set in Hotel application in oxe
Checkout if voice message = True ?
Or old non-consulted voice messages are still there
oldboy
Re: Voice guide
Post by oldboy »
What is the Voicemail type in the user?? Sounds like an Admin, is the guest deleting the Voicemail after they listen to it
seetharam r
Re: Voice guide
Sorry for delay,
Guest will not delete,
Whatsoever i tried leaving a voice msg on guest phone and i retrieved the same msg through the phone but whenever i receive the handset it says you have a msg.
HUSSAINQCS
Re: Voice guide
Have found solution ?
seetharam r
Re: Voice guide
no hussain
Re: Voice guide
After consultation (I hope guest listen message) - VM suggest - delete or archive messages?
HUSSAINQCS
Re: Voice guide
Just replace the voice guide with dial tone
junoooni
Re: Voice guide
Post by junoooni »
How do we change voice guide with dial tone?
Return to “Voicemail (46x5)”
