serial nr. of backup supplies
lisa
Post by lisa »
Hallo,
can I get all the serial numbers of backup supplies without deinstalling them and looking at each label?
I use OmniVista 2500 NMS 4.2.1.R01. When I create a report with the Inventory, I get only the serial number of the backup supply of the CMM-1, but not of CMM-2 or the normal stack members. This seems independent of AOS version; the effect is with AOS 6.7.1.108.R04 the same as with AOS 6.6.3.439.R01.
The command "show power" shows only whether a backup supply is present or not. The Web-Interface also gives me all the other serial numbers, but none of the backup supplies....
Sidlahar
Re: serial nr. of backup supplies
Post by Sidlahar »
Hi lisa,
this is a known bug and will be solved in a maintenance release 6.7.2R01 coming later this month.
Best regards
Sidlahar
Sidlahar
Post by Sidlahar »
Hi lisa,
the software is available now. The Fix is done in Release 6.7.2.80R01.
Best regards
Sidlahar
Return to “OmniSwitch 6450”
