Ring Tone did not heard when I call analog type
Waelkaamalzaki
Post by Waelkaamalzaki »
Dear Support team ,
Thanks in advance , I have OXE common hard ware ,My problem when I tried to call analog extension type , The ring tone did not heard by analog phone set,
please advice
Re: Ring Tone did not heard when I call analog type
Try another board.
All phones or a specific port?
If all, check board and voltage, if only one check port and if set works fine on another port
Waelkaamalzaki
thank you for your help
I did what you advised and found that it was a problem from analog set
