No RBT and silence when calling external number through ARS prefix
HUSSAINQCS
Hi All,
Suddenly in my site we faced issue when i dial external through ARS prefix there is no RBT and calls getting established but silence what could be the issue ?
HUSSAINQCS
Re: No RBT and silence when calling external number through ARS prefix
It was working earlier suddenly what happened i m not sure
Can anybody tell whether this issue from service provider PRA or from OXE
IN t3 trace i can able to see the calls establishing
I forgot my magic ball at home.
Show t3 trace.
Show t3 trace.
HUSSAINQCS
Hi Mr.Vad,
I will share the t3 trace but there is blank call for both incoming and outgoing as well this was happening for Service provider calls and we have avaya and oxe for that no issue i can able to call and i can hear RBT
HUSSAINQCS
Now It got rectified automatically is this issue with release 11.1 l301.37 ?
HUSSAINQCS
when i dial external no through ARS prefix it is showing Out of service but the PRA card is up and there where no errors in PRA card as well and there were no t3 trace what could be the issue ?
oxeman4400
change protocol type in your ARS to dependent on trunk group or other item and test it if it dose not work change protocol type in network routing number.
HUSSAINQCS
Suddenly when i receiving a incoming and making external PRA calls there is blank communication (call got answered)and there is no RBT also
But i can able to see the channels are getting busy this was happening to me third time
Has anyone faced the similar issue with R11.1 L1.301.37
I tried replaced the GD-3 card and tried rebooted the system but the issue still persists
do you have analog or ua phones in the same shelf like the pra... if yes, try to make calls from this type of phones...
regards...
regards...
HUSSAINQCS
Even with analog phone same issue and it was happening more than 5th time
Should upgrade the patch will resolve the issue ???
