Is it possible to get the caller id of the fax sender in the oxe ?
Scenario:
FAX sender------OXE fax----immediate fwd(ISDN PRA)--------Avaya FAX-(Receiver)
When the fax is send by the Sender so the receiver not able to see the caller id of the fax sender instead he can able to see the did managed for the FAX in the OXE side
Can anyone confirm whether the CLI of FAX sender can able to see in the Avaya side
or is there any way to get the cli of the fax sender in the oxe side ?
Caller ID for FAX calls
Re: Caller ID for FAX calls
Guess that as any extension, create a NPD for outgoing calls.
HUSSAINQCS
For getting the CLI of the fax sender in the Avaya FAX should i need to do through NPD
What option need to select ?
If you use OXE fax with immediate forward to Avaya - may be better just route incoming call directly to Avaya fax?
CLI in case of external forwarding depends of - System/ Other system/ External signalling parameters - item NPD for external forwarding
sadi_seemi
Hello
I also need help.....about DID Cli issue on incomming call....on another oxe node...
f.e. isdn DID pri terminated on oxe node 1.... All did of node 1 working perfect incoming and outgoing cli ok....but....DID of node 2 incoming call cli not display on set...outgoing cli is ok....
Node 1 and node 2 connected with ABCF configuration
