Mtracer, trc show nthg
MiaMia
Post by MiaMia »
i starte a trace with T3 and everything is fine.. i stoped it with <crtl><z> ... and now i will it start again and it Show
--> Cleaning mtracer...
--> Positionning T3 Filter...
Ttracers Analyser activated
mtracer already in use ...
an thats it
How can i stop it? or reactivat
tuner kmf and tuner km doesn't work..
Re: Mtracer, trc show nthg
Maybe you have another mtracer instance running.
Kill it as any other Linux program
MiaMia
Post by MiaMia »
kill or kill all mtracer doenst work...i try'd it..
HUSSAINQCS
Post by HUSSAINQCS »
Have you found the solution as cavagnaro explained try to stop the mtracer which is already running
dhs3_init -R MTRACER
and when you run t3 - for exit - use Ctrl-C
tgn
Post by tgn »
tuner km
regards...
MiaMia
Post by MiaMia »
thx all, but i get it:
kill -9 <procesID>
Eliott
Post by Eliott »
pkill mtracer or killall mtracer is easier
