OXE with FCS Voicemail
junoooni
Post by junoooni »
Hi all
I have integrated FCS voicemail with OXE 11.2.1 over VPS lines... OXE is configured as Hotel in Room Management mode
All rooms have analog phone with dedicated voicemail retrieval key (we have saved voicemail hunt group no. in it)
Caller can leave voicemail to room extension but i m facing issues with retrieval..
If we pickup handset of room extension dials directly to voicemail and voicemail answer with welcome prompt and announce no. of voice messages in mailbox... But if we press Voicemail retrieval button, it routes to voicemail hunt group and voicemail ask for extension and password...it should not ask extension and password but it should go directly to voicemail box like it do when we pick up handset...
Any thoughts????
HUSSAINQCS
Re: OXE with FCS Voicemail
Post by HUSSAINQCS »
Ask with FCS vendor
junoooni
Post by junoooni »
HUSSAINQCS wrote:Ask with FCS vendor
Nice suggestion but already did that and as per them they are not receiving call data which is the reason their system is asking for extension and password...
In the scenarion where we pickup the handset and call automatically go to voicemail they get call data
HUSSAINQCS
This is the message got from AAAP Interworking report
FCS Phoenix offers the following guest-centric features – • Voicemail: FCS Phoenix provides each guest with a personal voice mailbox during check-in. This means that voice messages are recorded directly in the recipient’s personal voice mailbox. Retrieving messages from the guestroom is easy and only requires dialling a single-digit number (speed dial) on the guest phone in the room. However, retrieving messages from outside the hotel requires guests to enter their unique PIN before permitting them to listen to their messages
junoooni
Post by junoooni »
HUSSAINQCS wrote:This is the message got from AAAP Interworking report
I configured using IWR...the behavior described for retrieving messages from outside hotel is what i am getting when trying to retrieve while inside hotel...we haven't given access to voicemail from outside
HUSSAINQCS
What about direct routing in phone COS ?
junoooni
Post by junoooni »
HUSSAINQCS wrote:What about direct routing in phone COS ?
Sorry...didnt get you here...which option you are talking about?
P.S. I am pretty new to OXE
HUSSAINQCS
try to do routing mode at off hook=delayed routing and give the routing no as external voicemail no
junoooni
Post by junoooni »
HUSSAINQCS wrote:try to do routing mode at off hook=delayed routing and give the routing no as external voicemail no
At off hook it goes to voicemail properly...
Only issue is retrieving voicemail using the dedicated voicemail key
HUSSAINQCS
Where the voicemail hunt group is configured ?
Return to “Hotel / Hospital”
