GD Board
rajansuruli15
GD Board
Post by rajansuruli15 »
Hi all,
We have upgraded a OXE from relase 6.1 to 11.2. its hardware is GD and CS board. CS is ok, after the upgardeation its working. But in GD board i am not able to get the login option. And seems its continuously rebooting....
This is the console output...and the same thing is repeating again in the console...
F ØAlize BIOS Monitor
memory test started lng= with
running flash(soldered=1 socket=0)= ,BIOScase: ,BIOSv24: ,verrou=
,algoNOR= ,siz
e= ,base=
DIMM characteristics->: JEDEC Manu ID:ê,......
Memory type(EDO,FPM..):0x
# of row address:
# of col address
# of module row
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI:scan_bus for bus
Exc : GpÒúÎAlize BIOS Monitor
,algoNOR= ,siz
e= ,base=
# of row address:
# of col address
# of module row
Exc : GpxüØ Alize BIOS Monitor
running flash(soldered=1 socket=0)= ,BIOScase: ,BIOSv24: ,verrou= ,algoNOR= ,siz
e= ,base=
# of row address:
# of col address
# of module row
Exc : GppüØ Alize BIOS Monitor
And i unable to reload the GD binaries also..
alex
Re: GD Board
Post by alex »
Looks like this board is faulty. It gets exclusion during PCI bus scan, also no RAM reported.
This is normal start of GD:
Alize BIOS Monitor
*** BIOS Version 3EH30227DQAA bios100/008.016 ***
*** Generated on Mar/20/2003 at 09:21 ***
memory test started lng=66060288 with 0
YOU CAN strike Ctrl B to enter in BIOS monitor during several seconds from NOW !
running flash(soldered=1 socket=0)=1,BIOScase:4,BIOSv24:0,verrou=1,algoNOR=1,size=1,base=3ff80000
DIMM characteristics->: JEDEC Manu ID:.,яяяяяя
Memory type(EDO,FPM..):0x04
# of row address:12
# of col address 9
# of module row 1
PCI:scan_bus for bus 0
PCI:bus=00h,devfn=00h ,[vendor:device]=[1022h/3000h]
PCI:bus=00h,devfn=60h ,[vendor:device]=[100bh/0020h]
PCI:bus=00h,devfn=98h ,[vendor:device]=[1064h/2101h]
PCI:scan_buses with 00h secondary buses
PCI:command =000003ffH for device 00:00
PCI: Assigning I/O space fc00-fcff for 00:60 BAR=00000010
PCI:Assign memory space bffff000H to bfffffffH for device 00:60
PCI:command =000003ffH for device 00:60
PCI:Assign memory space bfffd000H to bfffdfffH for device 00:98
PCI: Assigning I/O space fd00-fd1f for 00:98 BAR=00000014
PCI: Unable to handle I/O allocation for 00:98 (ff04) BAR=00000018
PCI:command =000003ffH for device 00:98
assigning irq10 to xchange
B0 = 17
DRCTMCTL = 1e
DRCCTL = 18
DBCTL = 11
Set external RTC
Set Internal RTC
No external RTC detected
