specific Multicast group not stream
HUSSAINQCS
Post by HUSSAINQCS »
Image[/img]I have 2 multicast source connected to the Avaya routing switch from there there where one up-link was coming to 6450(1/25)
and one uplink from 6450(1/26) is going to 6900(1/1/15)-----(1/49)6450----Multicast client
From the same Avaya routing switch there is one uplink going to Avaya core switch there they can able to see both the streams without any problem
In Avaya side they have pim sparse mode activated
vlan 901 -- Multicast client are in this vlan
Below are my config:
Avaya routing switch:
Multicast source 1: range(10.238.2.199)
Multicast source 2 :range (10.240.2.x)
6450-1 :
vlan 903 (1/25)untagged
vlan 901& 903 (1/26) tagged
In 6900 i have created dvrmp interface between vlan 903 & 901 but i can able to see the multicast source 1 range and i was not able to see the multicast source 2 range.
I need somebody advice on this please .
HUSSAINQCS
Re: specific Multicast group not stream
Please find the multicast setup
Return to “OmniSwitch 6450”
